Render out square pixels in AE? Please?
Laurie Pepper
on Mar 5, 2015 at 8:38:04 am
I have a big clip which was originally sent to Compressor from FCP7 and rendered out as 640 X 480 square pixels.
Which is what I wanted.
BUT When take a piece of that clip, bring it into AE to add an effect & then render it out with "Current Settings" it delivers
Pixel aspect NTSC - CCIR
But I WANT
pixel aspect square just like the original.
Any way to render out with square pixels? I understand default in AE is square, so...
What am I doing wrong?
Daniel Waldron
Re: Render out square pixels in AE? Please?
on Mar 5, 2015 at 2:07:01 pm
Have you checked your composition settings in AE to make sure it is set to square pixels?
Todd Kopriva
on Mar 5, 2015 at 3:42:22 pm
For others reading this thread, there is more detail on Laurie's duplicate thread here:
https://forums.adobe.com/message/7253081
After Effects product manager and curmudgeon
After Effects team blog
Laurie Pepper
on Mar 5, 2015 at 5:54:49 pm
Thanks Todd. Got annoyed with Response tonAdobe thread asking me why I want square pixels!? Anyway, I seem to have found what seems like a workaround since out render of AE comp with square pixels gives
Me larger clip with black space around the image. But if I look at it at 100% in FCP7, it fills the frame in correct FCP timeline setting.
Laurie Pepper
on Mar 5, 2015 at 5:48:30 pm
Yes, I did. Finally discovered which codec to use & in comp setting. it works but renders out a much larger clip with lots of black space around the edges. So when I bring it into fcp7 I have to bring it up to 100%% and image correctly fills window on correct timeline. Kinda sloppy but it works.
Laurie Pepper
on Mar 5, 2015 at 6:50:23 pm
SETTING
Dave LaRonde
on Mar 5, 2015 at 6:51:50 pm
Here's an easy way to do it:
  • Import the clip into AE.
  • Drag the clip onto the "Make Comp" icon at the bottom of the project pane. AE makes a comp in the frame rate, duration, resolution & pixel aspect ratio of the clip.
  • Open the resulting comp, and trim up the layer's in & out points to get the part you want.
  • Set the AE Work Area to the in & out points of the layer.
Render in the codec of choice.
Dave LaRonde
Promotion Producer
