Changing the "distance scale" of a composition - NOT the resolution scale (makin' ribbons)
Jordan Quackenbush
on Mar 4, 2015 at 10:51:47 pm
So I don't post unless I can't find something via Google. Hence, I'm here.
Issue: I'm trying to create some light/ribbon streaks using either Particular or 3D Stroke. Neither is a perfect solution, but could work My problem is that the camera-solved comp of an aerial skyline has Z distances of over 130000 between camera and a furthest null point, and things like 3D Stroke don't do that kind of distance well, at all, and Particular has a Far Vanish limit of 100000. Is there any way to scale the whole comp/unit distance down by 10? So 130045 becomes 13004.5, etc.?
Alternatively, if there's a better way to make 3d-ish arced strokes than 3d stroke or Particular, what would be recommended? Essentially following this tutorial: http://www.videocopilot.net/tutorials/light_streaks_2/ but on a large scale.
Jordan Q
Michael Szalapski
Re: Changing the "distance scale" of a composition - NOT the resolution scale (makin' ribbons)
on Mar 10, 2015 at 6:54:36 pm
Create a 3d null. Parent all of your scene elements to the null (created nulls, solids, the camera, etc.). Then simply scale the parent null down. See if that works.
- The Great Szalam
