Rotating noise to not face the camera
Joe Myles
on Mar 4, 2015 at 5:26:49 pm
Is it possible to rotate a solid with noise applied (turbulent, for example) so that the noise itself respects any rotation away from the camera that the solid has?
I've tried every combination of collapsing, pre-comp and 3d I can think of to no avail. For example, if I apply turbulent noise to a solid, pre-comp it and collapse the pre-comp with the contained solid set to 3d, it doesn't work. The pre-comp rotates as expected and the noise stays within the boundaries of the rotated pre-comp. In fact, it actually looks like it's doing everything perfectly until I look closer and see that the grid of noise is still following a perfectly horizontal and vertical grid rather than seeing the small noise squares at an angle.
Any ideas appreciated.
Walter Soyka
Re: Rotating noise to not face the camera
on Mar 4, 2015 at 9:42:40 pm
Joe, can you post a screenshot?
Effects are rendered before transforms, so even a noise effect applied to a 3D solid should show perspective and rotation.
Walter Soyka
Joe Myles
on Mar 5, 2015 at 12:00:50 am
Well this is embarassing. When I try and recreate the scene it works fine for the first time. I don't get it, I'm pretty familiar with the quirks of After Effects. Either I was crazy or discovered a bug that occasionally appears. Incase anyone comes across this from a websearch, this is After Effects CC 2014. The version that worked (though I had tried this several times before) was a 3d solid pre-comped into a composition that was collapsed.
Walter, I sincerely appreciate you stepping in to assist. Much appreciated.
