Change image source of a layer (Script)
Sergey Makarin
on Feb 26, 2015 at 12:05:28 am
I know how to change text in text layer (Works fine):
layer.sourceText.setValue(new TextDocument("Text Text Text"));
And need to change an image for image layer. But similarly the code doesn't work:
layer.sourceImage.setValue(new ImageDocument("c://image.jpg"));
Please write me correct code for changing image.
Walter Soyka
Re: Change image source of a layer (Script)
on Feb 26, 2015 at 1:22:40 am
Use an AVLayer's replaceSource() method:
app.project.item(index).layer(index).replaceSource(newSource, fixExpressions)
The source should be a footage item object, not a file path.
See p. 47 of the Ae CS6 scripting guide for more.
Walter Soyka
Sergey Makarin
on Feb 26, 2015 at 1:41:33 am
I think that the code must be like that:
layer.replaceSource(source, true);
but how to correct define "source" var?
Walter Soyka
on Feb 26, 2015 at 3:11:50 am
source is an object (AVItem?) from the project panel.
Walter Soyka
Sergey Makarin
on Feb 26, 2015 at 10:36:34 am
I found a solution:
source = new ImportOptions(File("c://image.jpg"));
