Using AE liquify tool on moving camera shot...?
chris stabile
on Feb 25, 2015 at 4:18:31 pm
Does anyone know how I would use the liquify tool on a moving camera shot? I've successfully used Andrew Kramer's awesome technique multiple times in my project, however only on shots with no camera movement (only subject movement). Now, I want to do it on a shot that has both camera and subject movement. Tis not going so well. thoughts?
http://library.creativecow.net/articles/kramer_andrew/Demon_Face_Warp.php
Tudor "Ted" Jelescu
Re: Using AE liquify tool on moving camera shot...?
on Feb 25, 2015 at 9:15:46 pm
Isolate with a garbage matte the face/part of body/object you need to apply the liquify tool on. Precomp and stabilize that. This should give you a relatively steady object (depending on how good the track is). Apply your liquify effect and then reverse stabilize and comp on top of original. This should work- at least in theory.
Tudor "Ted" Jelescu
Senior VFX Artist
Todd Kopriva
on Feb 28, 2015 at 4:55:39 am
See the section on reversible stabilization and the Warp Stabilizer VFX effect here:
http://blogs.adobe.com/aftereffects/2013/06/additions-to-warp-stabilizer-vf...
After Effects product manager and curmudgeon
After Effects team blog
