Mac spec
Adam Bulley
Mac spec
on Feb 19, 2015 at 10:47:37 am
Hey folks,
I'm currently working on a 3.06 GHz Intel Core 2 Duo iMac with 16GB 1067 MHz DDR3 ram. I've recently been doing tons of video projects and have found that the times needed for rendering and generally working in AE is making deadlines difficult to meet. I'm very tempted to upgrade to a Mac Pro setup and was hoping people may be able to give some advice. Pretty much all the work I do is in Premiere and After Effects.
I've been looking at the 6-core, with the idea of upgrading RAM to 64GB, or alternatively investing in the 8-core (although I'd probably not have funds to max out the RAM). Would I see a marked improvement over my current setup with either of these options? Also, what do people think is the best way forward for me?
Thanks for all help
Todd Kopriva
Re: Mac spec
on Feb 19, 2015 at 7:19:23 pm
If you decision is between 6 cores and maximum RAM or 8 cores and less RAM, I'd go for the former. RAM is great for After Effects, since it allows more things to be kept in the RAM cache and not need to be re-rendered or read from the disk cache.
After Effects product manager and curmudgeon
After Effects team blog
Adam Bulley
Re: Mac spec
on Feb 19, 2015 at 7:54:18 pm
Hi Todd, thanks very much for the feedback. Would you expect me to notice a big difference in previewing and rendering over my current iMac setup with the 6-core (64GB)?
Adam Bulley
Re: Mac spec
on Mar 20, 2015 at 11:50:03 am
Hi Todd
Just to say that I got the 6-core Mac Pro with 64GB RAM. On the whole very impressed! I'm now getting render times around 10 times faster than what I was having before!
The main thing I'm still disappointed with is the times associated with using the Magic Bullet plugins. Looking for a workaround at the moment to try and improve render times even further.
Thanks for your help
Adam
David Mason
Re: Mac spec
on May 23, 2016 at 8:41:30 pm
Hi Adam,
I believe I have a similar machine to the one you have. I've been having trouble getting my settings dialed in to really make After Effects fly but I am not having much luck. Any suggestions or recommendations on settings?
