what does brightness&contrast actually do to RGB value in AE CC2014?
andy blue
on Feb 13, 2015 at 7:21:54 am
The brightness value range is -100~100 In cs6,saying the value is 10,that means a RGB(200,100,100) would be 210,110,110.
In cc 2014,the brightness value range is -150-150,when i also change the brightness to 10,RGB(200,100,100)would be 212,107,107,I can't figure out how does it work。
Dave LaRonde
Re: what does brightness&contrast actually do to RGB value in AE CC2014?
on Feb 13, 2015 at 6:05:51 pm
This falls into the realm of asking, "Why do you need to be so precise?"
You can eyeball Brightness/Contrast to taste with pretty good success, and as long as you don't violate maximum/minimum video levels (assuming you work in video), you should be okay.
Dave LaRonde
Promotion Producer
