After Effects 6.5
Daniel Klinger
After Effects 6.5
on Feb 12, 2015 at 9:09:12 pm
I'm using After Effects 6.5. I'm trying to render a video with some audio with it. Only when I render the video the audio isn't there. What am I doing wrong? Thanks for your help.
Spencer Tweed
Re: After Effects 6.5
on Feb 12, 2015 at 10:28:35 pm
Hahahahahaha, 6.5?! hem-hem, sorry.
What you need to do is click on your output settings in the Render Queue (probably where it says "Lossless") and at the bottom of the Output Module Settings window you will see a checkbox for audio output.
- Spencer
Daniel Klinger
on Feb 12, 2015 at 11:31:06 pm
Thank you so much. I'll check it out. Appreciate your response. Dan
Brian Charles
on Feb 12, 2015 at 10:32:00 pm
I don't have access to 6.5 so I'm not able to accurately describe the dialog box, but in the output module settings dialog at the bottom is a checkbox to enable audio output.
In CS6 it looks like this:
Daniel Klinger
on Feb 13, 2015 at 12:00:41 am
Thanks for your help. I'll give it a shot. I noticed that the output audio was off in the render queue. I'll have to check to see how to turn it on. Thanks again for your help. I appreciate you taking the time to respond back to me. I'd like to have a newer version of After Effects. Do you know of a resource that sells older or used software? Just wondering.
Thanks again for your help. Dan
Daniel Klinger
on Feb 13, 2015 at 2:28:44 pm
Thanks for your help. I finally got it figured out last night. Once you know how it works pretty well.
Thanks again, Dan
Dave LaRonde
on Feb 13, 2015 at 6:08:54 pm
And since you run AE v. 6.5, here's some advice:
DO NOT UPGRADE YOUR OPERATING SYSTEM.
If you do, you'll get a nasty surprise: your version of AE doesn't work any more.
Dave LaRonde
Promotion Producer
Daniel Klinger
on Feb 13, 2015 at 6:17:20 pm
Thanks for the heads up. I already have AE 6.5 on Windows 7. So I wasn't planning on upgrading my operating system. I would like to upgrade to a newer version of AE if I can without a lot of expense. Although I am just beginning to understand 6.5.
Thanks for your thoughts. I appreciate them.
Dan
Daniel Klinger
on Feb 13, 2015 at 7:42:38 pm
Okay. Thanks!
