CC Time Blend FX Keyframing Issue
Andrew Cibulas
on Feb 12, 2015 at 4:24:58 am
I am currently trying to render a video of startrails using AE. I have been adding 4 keyframes (a set to ramp up accumulation from 0-95 and then another to bring it back down from 95 to 0). Whenever the video reaches the second keyframe (arriving at 95), the effect appears to cut out very briefly, and then come back in. What it looks like is a gradual ramp up to star trails, then a flicker and a continuation of the star trails. I have tried rendering with the keyframes set on just about every possible setting and have looked online for a solution, but no matter what I do it still seems to persist. The other effects I am using in my video are time stretch, motion blur, and warp stabilizer.
Thank you for any help with this.
Walter Soyka
Re: CC Time Blend FX Keyframing Issue
on Feb 12, 2015 at 11:42:22 am
Have you tried clearing your cache?
Ae CC/CC2014:
Edit > Purge > All Memory & Disk Cache
Ae CS6:
Preferences > Media & Disk Cache > Empty Disk Cache
Also, if you are running Ae CS6, make sure you've installed the updates. The persistent disk cache feature was new in CS6 and there were a good number of bug fixes in the CS6 point releases.
Walter Soyka
Andrew Cibulas
on Feb 12, 2015 at 11:54:16 am
Yes I have cleared the cache. I will double check updates when I get home from work this evening and let you know. Thanks!
