Make text fan out like deck of cards using after effects.
Alex Siegel
on Feb 10, 2015 at 9:14:08 pm
I am trying to make my text follow the video footage you can find at the link below from Videoblocks. Basically as the cards are spread across the table I want the text "Las Vegas" to spread out underneath it. I want it to look like the text is apart of the cards. Is this possible in After Effects without plugins?
http://www.videoblocks.com/video/card-shuffling-trick-at-casino-with-gambli...
John Cuevas
Re: Make text fan out like deck of cards using after effects.
on Feb 11, 2015 at 1:11:59 pm
You can do that quite easily with text animators. Check out the free tutorials on them by Andrew Devis, about halfway down the page. If after you watch them and you have some more specific questions, just ask.
Also, you might want to check out the Adobe Browser and navigate to the preset text animators, you might find one that perfectly suits your needs.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
