After effects workflow question
Keane Morrissey
on Feb 8, 2015 at 10:49:05 pm
Lets say I want to color grade my whole Final Cut project, should I grade each RAW clip individually then edit in FCP? If you do grade each RAW file wouldn't take take too long since I only use a portion of the raw clip? or should I import that whole, edited, FCP project to Grade in after effects? How do you color grade each individual clip when after effects recognizes your edit as a single clip?
John Cuevas
Re: After effects workflow question
on Feb 9, 2015 at 2:53:11 am
If you did it in AE, I would use the split clip command (shift+cntl+D). You could also try Edit Detection Script
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Keane Morrissey
on Feb 9, 2015 at 4:34:47 am
Thanks for the tip. Still looking for answears
Keane Morrissey
on Feb 10, 2015 at 3:56:07 am
Thanks again for your time, To anyone reading the solution is to edit using Adobe Premiere Pro which works hand in hand with After Effects
