Making Presets - After Effects error: internal verification failure, sorry! {unexpected match name in group} (29 :: 0)
Bijan Sam
on Feb 7, 2015 at 1:00:03 am
I am attempting at making a preset for myself, because I want to speed up the time it takes to make and add effects to layers.
I began by using an online generator to generate my preset shell (the outline of the preset). I then took the code it gave me, and
pasted it into my PresetEffects.xml (C:\Program Files\Adobe\After Effects CC 2014\Support Files\PresetEffects.xml) and when I went
into After effects CC, I opened up the script editor (File>Scripts>Open Script Editor), then I pasted my import java code:
app.project.activeItem.layer(1).effect.addProperty("Audio_Waveform_Wheel");
When I press the "Run" button, something happens, then on my after effects a pop up message comes up saying:
When I press OK, it just opens up again. My software also looks a little messed up. What is going on?
How do I fix this issue?
Todd Kopriva
Re: Making Presets - After Effects error: internal verification failure, sorry! {unexpected match name in group} (29 :: 0)
on Feb 7, 2015 at 3:02:48 am
Install the most recent update. You are using an out-of-date version of After Effects.
After Effects product manager and curmudgeon
After Effects team blog
Bijan Sam
on Feb 7, 2015 at 4:33:59 am
Hey! I was wondering if I am able to do it with any version of after effects? Or do I need the latest to make presets?
For example, can I use Adobe After Effects CS5.5 to make presets? Or will it crash as well?
Michael Szalapski
on Feb 10, 2015 at 6:23:14 pm
You should be able to make presets in other versions. Todd was just saying that the version you were using needed to be updated to fix bugs.
- The Great Szalam
