Solo layer must be clicked or layer invisible
Clayton Light
on Feb 5, 2015 at 7:54:38 pm
I was working as normal. I must have done something I don't recall. The result was that my layers must have the solo button on or they are invisible even though the eyeball for the layer is on. What did I do? How can I fix this? Anybody seen this before?
Jeff Hinkle
Re: Solo layer must be clicked or layer invisible
on Feb 5, 2015 at 8:25:24 pm
I saw that once where a coworker solo'ed a layer that started outside the comp, then made it Shy. Couldn't figure out why everything was invisible. Similar situation?
It is easier to destroy than to create.
More fun, too.
Daniel Waldron
on Feb 5, 2015 at 8:32:37 pm
Can you see any layers without the solo button clicked? If not, Jeff is probably correct and there is hidden or locked layer that is solo'd, but not visible in your comp view.
Clayton Light
on Feb 5, 2015 at 8:37:01 pm
Wow, that was it. Thanks guys.
