Reversing/inverting the direction of shape layer paths
Lasse Gjertsen
on Feb 5, 2015 at 1:28:03 pm
I'm using shape layer paths to animate shapes, which is nice because of the interpolation. Up to this point I didn't think it was possible to reverse the direction of the path in an easy way.
While working I have accidentally flipped the direction of one of the keyframed paths, probably by hitting a hotkey.
Anybody knows what this shortcut might be, or how to reverse the path direction by other means?
I'm using CS6.
Michael Szalapski
Re: Reversing/inverting the direction of shape layer paths
on Feb 5, 2015 at 2:12:21 pm
If you twirl down your path layer's properties on the timeline, go into the contents into the properties for your shape and next to the shape path is a set of icons with arrows. Click the one that's not pressed.
- The Great Szalam
