Frame Rates
Eugene Constable
Frame Rates
on Feb 3, 2015 at 5:41:48 pm
I need to create footage that looks aged and jerky - projected. sort of 8mm projection
Fine with getting the look but stuck on frame rates..
I have rendered out the movie from after effects at 12fps
I then import the rendered file into premiere to a seq set to 25fps (I'm in the UK)
does this mean the nice jerky motion will get smoothed out?
Or, in AE should I nest the footage, change the nested comp to 12fps use preserve frame rates on the nested comp and render it out at 25 to go into Premiere?
bit unsure of best method.
Thanks in adv,
Dave LaRonde
Re: Frame Rates
on Feb 3, 2015 at 6:50:23 pm
It would be easy to put the 12fps footage in a 25fps comp and render.
Because of the odd frame rate disparity it will look jerky because it's 12 fps, with an occasional extra jerk every couple of seconds because it's 12 fps spread across 25fps.
You want jerky? You'll get it.
Dave LaRonde
Promotion Producer
© 2018 All Rights Reserved
