alpha channel batching
Alan Stephens
on Feb 1, 2015 at 1:55:01 pm
Is there a way to batch Animation files with an alpha channel?
I have a to of lower third seminar points to produce.
Does media encoder have a way to support alpha channels.
I can batch my full page with backgrounds no problem, but I don't see a codec that supports alpha channels.
Alan Stephens
Mac Book Pro 2.6, quad i7, 8 GB Ram, NVIDIA GeForce GT 650M 1024 MB, OS X Mavericks 10.9.2
Thunderbolt Promise raid drive
Daniel Waldron
Re: alpha channel batching
on Feb 1, 2015 at 8:56:28 pm
The Animation codec has an alpha channel. Make sure you set it to output RGB+Alpha in the Output Module settings. You can save that as a preset and export as many lower thirds as you would like. :)
Alan Stephens
on Feb 1, 2015 at 10:05:08 pm
I have been using the method you sent in the screen capture, only exporting one at a time.
Each time I have to reset the RGB + Alpha. Sometimes I forget. I've had over a hundred of these to do.
How do I save it as a preset? I don't see any options here.
Can this preset be used in Media encoder with the Alpha channel?
Alan Stephens
Daniel Waldron
on Feb 2, 2015 at 12:40:47 am
Click the small arrow next to where you select the format in the Render Queue and go to the bottom where it says "Make template". You can name it whatever you like. This preset will be saved and will also be available in Media Encoder.
Alan Stephens
on Feb 2, 2015 at 2:22:01 am
Ok I made a new template and I can access in AE, but it doesn't show up in media encoder.
I saved all to my documents, then tried to import in media encoder, but it was greyed out.
How do I make it available to media encoder?
Alan Stephens
Daniel Waldron
on Feb 2, 2015 at 2:30:41 pm
I just tried it and it seems the presets only appear in AME when you make them in Premiere. No matter, you can make a preset right from within AME. Click the + button that is in the Preset browser, then set it to Quicktime Animation. To add an Alpha channel, set the Depth option to 32 bit. That should do the trick.
Alan Stephens
Re: alpha channel batching SOLVED
on Feb 2, 2015 at 3:32:57 pm
This is fantastic! It works great and will save me so much time.
Thanks so much!
Alan Stephens
Daniel Waldron
on Feb 2, 2015 at 3:34:29 pm
Great! Glad it worked. :)
