Illustrator graphics become blurred when pre-composite
billy zi
on Jan 30, 2015 at 10:29:55 pm
Hi I have attached imgs and file that explain my problem. So as img 1 shows, I got a vector layer(collapse transformation is on) and I pre-composed it and then I add puppet tool animate the hand. As img 2 show, I move the L_hand comp into the main comp. at last, I got blurry when i try to scale it. But when I turn on the collapse transformation, as img 3 show, the graphic is not blurry but it ruins the animation. The animation is not working.
here is the file:
8473_hand.zip
thanks
Walter Soyka
Re: Illustrator graphics become blurred when pre-composite
on Jan 31, 2015 at 11:17:11 am
When you use collapse transformations, it changes the render order for affected comps and layers. Instead of rendering the inner layers of a precomp inside the precomp, then rendering the precomp itself as a layer with the main containing comp, collapse transformations basically pulls the precomp's layers into the main comp and then applies any transforms/effects done to the precomp layer itself directly and individually to all its contained layers.
As you've noted, this can have a really drastic and perhaps unexpected result.
Your simplest solution here is probably to scale up in the precomp to the maximum size you'll need and leave collapse transformations off.
Walter Soyka
billy zi
on Feb 2, 2015 at 6:09:11 am
