Keylight problem on noisy (video) footage
mark thompson
on Jan 29, 2015 at 11:04:20 pm
Hi, I have a problem with Keylight on noisy footage. The person talking is in a studio with lots of light on a good green screen. Keylight keys the subject out but I omitted to light the legs below the knee. When I look at the source footage you can see noise there but when the key is applied it gets very noisy.
If you look at
from surfaced studio, at the end 5:54 on the Osaka Snake shirt you can see the effect I'm experiencing. However mine is much worse when I render.
Anyone have any ideas what can be done to damp it down?
CC 2014, footage is 50 MHz 4:2:2 25p.
thanks
Mark
Dave LaRonde
Re: Keylight problem on noisy (video) footage
on Jan 30, 2015 at 12:05:28 am
Keylight's a good keyer, it just likes green screen backgrounds a little dark. Sounds like yours might have been a little bright.
I handle the problem by using the keylight status window to ensure that the key is right: solid at the core, gray edges. Once it's good, I change it back to the final output and use it as an alpha matte for an unkeyed duplicate layer of the shot.
Dave LaRonde
Promotion Producer
Todd Kopriva
on Jan 30, 2015 at 12:09:14 am
Use the Key Cleaner effect with Keylight:
http://blogs.adobe.com/aftereffects/2014/04/new-changed-after-effects-cc-20...
After Effects product manager and curmudgeon
After Effects team blog
mark thompson
on Jan 30, 2015 at 10:30:05 am
Todd,
thanks for that suggestion. I have to study it some more but I latched on to "Reduce Chatter", otherwise using default settings, and it made a huge difference.
mark thompson
on Jan 30, 2015 at 10:34:36 am
Dave thanks for that. I will try that approach after I've done some re-shoots.
mark
Tudor "Ted" Jelescu
on Jan 30, 2015 at 7:30:55 am
Use Intermediate Result from Keylight - this solves a lot of noise issues.
Tudor "Ted" Jelescu
Senior VFX Artist
mark thompson
on Jan 30, 2015 at 1:17:53 pm
Ted,
could you expand on that a bit?
thanks
mark
Tudor "Ted" Jelescu
on Jan 31, 2015 at 8:17:31 pm
Using the "Intermediate Result" instead of the "Final Result" in Keylight removes some of the automated colour correction which can introduce artifacts and noise. I have been using this setting in most of my chroma projects combined with AE's Spill Reduction and it works for most of my work. Of course in most projects I use the same tested setup with a well lit chroma and plenty of light, but I found this to work just fine in chroma footage that I received from other sources with a not so great setup.
Tudor "Ted" Jelescu
Senior VFX Artist
