Canon c300 MXF - Color management
Martin Fisher
on Jan 29, 2015 at 9:00:54 pm
Hi there,
I have to work on some MXF files shoted with Canon C300 on C-Log.
When I import the files on AE CC, under color management I see "Embedded Profile: HDTV Rec 709 YCbCr.
The image doesn´t look Log. It´s like a LUT had been applied to it. I assume it is because of the embedded profile, am I right?
What would be the proper way to import and export the files so they can be color corrected in Assimilate Scratch after my work?
Any thought would be appreciated.
Thanks !
Walter Soyka
Re: Canon c300 MXF - Color management
on Jan 30, 2015 at 1:49:39 pm
You will almost certainly not want to do your effects work in log, so you'd need something like a C-Log to Rec.709 LUT. AbelCine has published some here:
http://blog.abelcine.com/2013/12/04/canon-luts-for-the-c100-c300-and-c500/
But of course I'm not sure what it is you're seeing now. Can you post a screenshot?
Walter Soyka
