realtime preview
Marc Nibor
realtime preview
on Jan 29, 2015 at 10:38:52 am
is there a way to get make footage play in realtime inside of AE without the need of rendering the frames?
I need to do some work where i have to line up some footage on the timeline prior to start with effects etc.
it's extremely timeconsuming to render a preview each time i moved the footage for a few frames from left to right.
Since it's really just the lining up of the clips that I need to do first I think if there is no way to do this in AE it might be a good idea to do it in premiere the then somehow move it to AE.
Is there a standard workflow for this?
Tero Ahlfors
Re: realtime preview
on Jan 29, 2015 at 11:06:09 am
[Marc Nibor] "is there a way to get make footage play in realtime inside of AE without the need of rendering the frames? "
Depends on the footage and your computer. Usually, nope.
[Marc Nibor] "it might be a good idea to do it in premiere the then somehow move it to AE."
Yep. You can import Premiere sequences into AE or copy paste from PR to AE.
Marc Nibor
on Jan 29, 2015 at 11:11:12 am
[Tero Ahlfors] "Depends on the footage and your computer. Usually, nope."
the speed of my machine should not be the issue since it's very fast. which setting enables the "realtime" preview - if there is any?
Tudor "Ted" Jelescu
on Jan 29, 2015 at 11:15:35 am
No real time preview in AE, not yet.
Work in Premiere and then import in AE like it was suggested
Tudor "Ted" Jelescu
Senior VFX Artist
Marc Nibor
on Jan 29, 2015 at 11:19:35 am
Thanks to everyone. I'll do that!
