Poor render with audio
Pat Trimmer
on Jan 29, 2015 at 12:41:27 am
This is the first time I've needed to render with sound (I have titles on a text layer over the action), and I was actually able to figure out how to do that. When I Ram previewed, the action was jerky and even froze for a second. Then the sound went out of sync. Needless to say, that's how the rendered clip looked, too.
Is there a way to fix this? I'd ask what's going on, but I probably wouldn't understand the answer.
Pat
Tudor "Ted" Jelescu
Re: Poor render with audio
on Jan 29, 2015 at 7:35:39 am
What version of AE, what OS and what codec is the clip with audio?
Tudor "Ted" Jelescu
Senior VFX Artist
Dave LaRonde
on Jan 29, 2015 at 8:02:48 pm
In addition to Ted's clarifying questions, I'm going to add this:
If you've timed out your AE animation to sound effects, and all is good after repeated RAM Previews, forget the audio. No fooling. Just render video.
Bring the AE animation into a video editing application along with the sound effect files, sync everything up in it, get the audio levels right, and you're good to go. Export for final delivery from the editing application.
You have a LOT more control over audio in an editing app than you do in AE.
Dave LaRonde
Promotion Producer
Pat Trimmer
on Feb 8, 2015 at 1:49:47 am
Hi Dave,
Sorry for taking so long. I imported a shorter clip and applied the animation. When I exported that as Quicktime, the clip still played all jerky and with out-of-sync sound. I don't understand the electronics behind things like this, but thanks to you I went ahead and imported it into Final Cut without the sound track and pasted it on top of the existing footage. It played perfectly in FC and when I exported the whole project to Quicktime. Thanks!
Pat
Pat Trimmer
on Jan 30, 2015 at 6:10:23 am
I'm pretty sure it's CS6, OSX, and ProRes422.
Tudor "Ted" Jelescu
on Jan 30, 2015 at 7:28:21 am
Clear cache - I remember that fixed some audio issues once in CS6. However, Dave's advice is the way to go- render the video and sync up audio in an editing package.
Tudor "Ted" Jelescu
Senior VFX Artist
Pat Trimmer
on Feb 8, 2015 at 1:52:07 am
Thank you. I intend to do that. I appreciate the help.
Pat
