How to keep items from quivering/ shaking in a layer in after effects?
sam debey
on Jan 28, 2015 at 5:40:17 pm
Hello,
I apologize in advance if this has already been answered somewhere ( i checked but found nothing)
but here is my problem:
I am importing static Flash layers into After Effects and when i animate the layer in after effects parts of the layers dance around a bit.
For example I have a little bit of text I wrote in flash and then i expand the text in after effects and the letters wobble around a bit.
Another example. I have a diagram made up of different layers in flash and when i do a zoom in after effects the parts move around a bit rather than staying as a solid image.
Any advice as to how to fix this would be greatly appreciated!
Sam
Dave LaRonde
Re: How to keep items from quivering/ shaking in a layer in after effects?
on Jan 28, 2015 at 7:15:11 pm
Read up on the use of Hold keyframes. They freeze a layer's position until the next position keyframe is encountered.
Make sure the position value of the hold keyframe and the next keyframe are identical or you'll see a jump at that next keyframe.
Dave LaRonde
Promotion Producer
