Can't see Motion Paths?! (with display option selected)
Ben Hartley
on Jan 28, 2015 at 11:50:35 am
I can't see motion paths even though I have them selected in Display settings. I found someone else who stated turning off time stretch solves this but this has not solved the problem either. Opening project in either CS6 or CC has same issue.
In desperate need to solve this. Any suggestions?!
If it looks good, look at it.
Dave LaRonde
Re: Can't see Motion Paths?! (with display option selected)
on Jan 28, 2015 at 4:20:02 pm
Do you have the layer's Position property highlighted?
Dave LaRonde
Promotion Producer
Ben Hartley
on Jan 28, 2015 at 6:52:07 pm
I do indeed. Very annoying problem.
Todd Kopriva
on Jan 28, 2015 at 7:37:21 pm
Do you have Show Layer Controls enabled?
After Effects product manager and curmudgeon
After Effects team blog
Dave LaRonde
on Jan 28, 2015 at 9:04:53 pm
I can't tell which AE version you're running. But if you're on a Mac, and you recently changed the OS to Yosemite, you'll want to update your version. Never mind if it says you're already updated. Do it anyway.
Dave LaRonde
Promotion Producer
Ben Hartley
on Jan 29, 2015 at 11:47:51 am
@ Todd - Yes I have Show Layer Controls selected.
@ Dave - I am using AE CS6 with Mac OSX 10.9.5
- Ive opened up the project file WITHOUT motion paths showing within a completely differect project that DOES have a comp with motion paths showing, im not sure what this says? Its something wrong with the comp or project and not AE?
Ben Hartley
on Jan 29, 2015 at 3:05:16 pm
I believe it may be something to do with this PSD file im using as my BG as I inserted it into a project with motion paths working and it shows as invisible, any suggestions?
8469_babybelbg.psd.zip
Dave LaRonde
on Jan 29, 2015 at 8:11:20 pm
All I see is a Photoshop Document with layers. I don't see an AE project.
And before you go any further, did you double-check that you're following Todd Kopriva's advice? Did you check that setting? Not that you just THINK you got the right setting, but found those precise words in AE?
Todd is, after all, Mr. After Effects -- the gent is in charge of AE for Adobe, he wants to see AE users succeed, and his words are to be taken seriously.
Dave LaRonde
Promotion Producer
Ben Hartley
on Feb 2, 2015 at 3:28:40 pm
Sure see attached AE project file with just the null I need to show motion path with.
And yes I definitely have Show Layer Controls enabled.
8483_nomotionpath.aep.zip
Ben Hartley
on Feb 26, 2015 at 12:49:02 pm
Any ideas on this?
Ben Hartley
on Apr 13, 2015 at 4:36:50 pm
PLEASE could anyone help me with this it really is an issue for my workflow, any help much appreciated!
Ive even tried installing CC and still no motion paths with the setting selected on ALL KEYFRAMES in preferences.
Stephen Mendenhall
on Apr 24, 2015 at 6:57:48 pm
Go to view>view options
Try turning it on from there. Let me know if this works out for you.
Daniel Barham
on May 6, 2015 at 3:09:11 am
try Ctrl+Shift+H
