Dealing with Color Shifts: dynamic-linked AE comps in Premiere Pro
M. Bernard
on Jan 26, 2015 at 8:44:39 pm
Hi, I have posted this in Premiere Pro forum as well, due to the issue involving both platforms.
Are there any suggestions on how to bypass, or properly set, the color space in After Effects, for AE comps I bring back into Premiere Pro, that appear to have a color shift?
I finished and color graded a project entirely within Premiere Pro (using Red Giant Colorista II and Magic Bullet looks), but have had to reopen the project and bring parts of it into After Effects to apply motion and transitions between clips. I can't figure out a workflow, or the appropriate AE color space to use within AE 'Project Settings', that allows me to avoid the color shift when an AE comp is brought back into Premier, ie via dynamic link comps or an imported PP project into AE..
Regrading the affected segments is an option, but I was hoping to avoid that and figure out a good game plan for the future.
The closest match seems using sRGB IEC61966-2.1 with only Linearize Working Space selected, but there appears to be a tint and gamma shift going on.
I followed this example for forcing the dynamically linked AE comp to output a comparable look back into the PP project ( https://forums.creativecow.net/thread/2/1052523 ) but the difference is I graded within PP, not in an AE RGB space, and applying the Color Profile Converter and enabling display settings on an adjustment layer did not help.
Apologies for what must be my rudimentary knowledge of color spaces and color processing between platforms..
Thank you!
Matt
Premiere Pro CC 2014
After Effects CC 2014
Mac OS X 10.9.5 (13F34)
21.5-inch, Mid 2011
Processor 2.8 GHz Intel Core i7
Memory 12 GB 1333 MHz DDR3
Graphics AMD Radeon HD 6770M 512 MB
Walter Soyka
Re: Dealing with Color Shifts: dynamic-linked AE comps in Premiere Pro
on Jan 29, 2015 at 4:26:53 pm
Any chance you can post a short clip? I'd like to try to rebuild what you're doing here and see if I can understand your workflow.
Walter Soyka
Paul Whishaw
on Dec 16, 2015 at 4:56:42 pm
Anything happen with this thread?
