Text changes position when I enable 3D and vice versa when I turn 3D off
ashley baron
on Jan 23, 2015 at 7:32:25 pm
So I've been working in this after effects comp and when I rendered it out, my text had moved out of place in the final rendered video. When I went back in I noticed that when I turned the 3D switch off it moved to the position where it was when it rendered out... I have 10 other comps in this project and none of the other ones are doing this so I don't know what I'm doing wrong in this one. What other info do you need to help me figure this out?
Dave LaRonde
Re: Text changes position when I enable 3D and vice versa when I turn 3D off
on Jan 23, 2015 at 7:50:49 pm
Here's a no-brainer workaround: copy one of the text layers that works and paste it into the problem comp.
Dave LaRonde
Promotion Producer
Walter Soyka
on Jan 24, 2015 at 1:37:12 am
Are you maybe looking at some view other than Active Camera in the viewer for that comp?
Walter Soyka
