Connect Layers to anchor point generated by Newton then apply a texture
Scott Green
on Jan 21, 2015 at 2:18:29 pm
I want to animate a childs tree swing swinging using Newton, then using the AEscripts Connect Layers script with the 'Rope' option to join them. I then want to apply a realistic rope texture to it instead of just a normal stroke line.
I don't think this is going to be possible using Layer Styles and I think I might run into problems if I try and use the Puppet Tool to try and apply the texture to the it and make it follow the movement accurately.
Any other ideas would be a great help.
Thank you.
Splurj Creative, Video Production, Motion Graphics & Animation in Manchester UK.
Michael Szalapski
Re: Connect Layers to anchor point generated by Newton then apply a texture
on Jan 22, 2015 at 3:34:57 pm
What kind of animation are we talking about? If the rope isn't going to bend, but is just going to be a fairly straight line, this should be pretty easy to do with the puppet pin tool. Just tie a pin to the swing layer's position with expressions.
- The Great Szalam
Jason Jantzen
on Jan 22, 2015 at 7:10:19 pm
I just used Puppet Pins and animated the swing with some Newton chains (squares attached with joints and the bottom one had a spring joint I think just for fun).
Or like Michael says, you could simply use some expressions to make it swing about. I like to use the animation tools in the DUIK script, which are free, to create a quick IK chain, then animate the bottom null (connected to the pin, or "bone" with DUIK).
Jason Jantzen
vimeo.com/jasonj
Scott Green
on Mar 3, 2015 at 1:39:09 pm
Does anybody know how to move the anchor point of a joint in newton?
I don't want my anchor point centered I want it placed more near the top of the object?
Jason Jantzen
on Mar 3, 2015 at 6:18:58 pm
The shortcut is Y. It's the same shortcut for the pan behind tool which consequently is how you move any layer's anchor point outside of Newton.
Jason Jantzen
vimeo.com/jasonj
Scott Green
on Mar 4, 2015 at 12:54:19 pm
That's the one key I didn't think of, thanks Jason :)
