Problem with resolution
Dennis Piilgard
on Jan 21, 2015 at 9:59:21 am
I'm trying to export an animated PNG file. It's a logo, which is animated as a waving flag, but when it waves the resolution becomes poor. Otherwise the logo is perfectly sharp.
I have imported it as a PNG-24 with a resolution of 5000x1641 (tryed to increase the res to see if that worked - the previous version was 1191x391). The composition settings are 1920x1080 and I have tryed both H.264, uncompressed 8bit and as a DPX. It still seems blurry when animated both in AE and imported into Premiere.
I have used Fractal Noise, Turbulent Displace and Fast Blur to create the animation.
Any ideas where it might go wrong?
Dennis Piilgard
Re: Problem with resolution
on Jan 22, 2015 at 10:47:21 am
Could it be, that some of the effects is having a negative impact on the rasterization? I tryed to use the 'continuous rasterize', but that didn't help either..
