Possible to enter location/orientation coordinates manually?
Kelly akers
on Jan 19, 2015 at 6:18:19 pm
Hi I'm trying to give two solids parallel orientation (with one "above" the other) but it's really hard to get the exact location I need by moving my mouse around. Is it possible to type in the X, Y, Z axis orientations manually?
Kelly akers
Re: Possible to enter location/orientation coordinates manually?
on Jan 19, 2015 at 6:24:22 pm
Ah! Never mind, I figured it out. Right click > Transform > Orientation, duh. I'm used to Vegas so it's a learning curve.
Dave LaRonde
on Jan 19, 2015 at 6:39:04 pm
You can also type in numeric values for position and orientation. You do it using the layer's twirl-down, locating the value and typing it in.
Dave LaRonde
Promotion Producer
