Out Problems
kingsley asumadu
Out Problems
on Jan 18, 2015 at 8:13:26 pm
Hi Guys.
I'm having problems trying to render (output) my project.
The project is 40 minutes, it renders about 3/4 and then stops with an error message.
Here is the system I'm running:
iMac OS X 10.9.5
3.4 GHz Intel Core i7
24 GB 1600 MHz DDR3 memory
NVIDIA GForce GTX 680MS 2048 MB
Here is an image of the error.
Thank you in advance,
Kingsley.
Derek Boettcher
Re: Out Problems
on Jan 19, 2015 at 7:53:25 am
Will at 40 min, that would be very taxing on a system through ae rendering. It sounds like you had run out of allocated memory.
Double check in you preferences that you have given as much ram as possible for your rendering. Also, if you are running gpu acceleration, your GUI could be running out of memory. My personal opinion would be to break up the project into smaller bite size pieces and then compile them in a nonlinear editor and export again. Your computer will just like you better.
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
kingsley asumadu
Re: Out Problems
on Jan 19, 2015 at 3:51:41 pm
Thank you so much Derek,
I haven't yet tried your suggestion yet as I'm currently away from the computer.
I think this will be my best shot at getting the project done.
I've search for solutions everywhere with no answers.
Thank you,
Kingsley.
