[Kendall Shaw] "All layers are meant to fit the composition size currently. Obviously, this won't always be the case. I can use fit to comp, once I find out where I have bumped the video. But, is there a way to lock the position so I can't accidentally bump it?"
You can lock the layer.
You can also use an expression for the position, so that it will override keyframes. For example, if your position is [960,540] and you want to lock that, alt+click the position stopwatch and enter the following expression:
[960,540]
Walter Soyka
Designer & Mad Scientist at
Keen Live [link]
@keenlive [twitter] |
RenderBreak [blog] |
Profile [LinkedIn]
