Trigger layer to play forward from 0 on a particular slider value
Benjamin Zaugg
on Jan 18, 2015 at 7:26:09 am
Hi, this is my first post. I hope somebody can help me out.
In my composition I have a precomposed layer sitting in my comp that I would like to play from frame 0 onwards whenever my slider hits 9.
It was easy enough for me to tell my animation layer to jump to frame 0 when triggered, but I have no idea how to get to it to play forwards from 0.
This is the code I have currently sitting in my layer's time-remap bit:
x = thisComp.layer("emoji ").effect("emojiRounded")("Slider");
if (x == 9){
0
So obviously it just jumps to 0 and stays there until the slider changes.
What I want is for it to jump to 0, then ignore the slider's continued "9" value in subsequent frames while it plays for 2 seconds. It would be good if it then could be triggered again after 2 seconds.
Ben.
Walter Soyka
Re: Trigger layer to play forward from 0 on a particular slider value
on Jan 18, 2015 at 5:45:22 pm
Expressions are evaluated anew every single frame; they have no memory from frame to frame or knowledge of previous states.
To get the animation to play forward, you have to test not just for when to trigger a play cue, but also to test if it should be playing and if so, what frame it should be showing.
Check out this example:
http://www.motionscript.com/design-guide/marker-sync.html
Walter Soyka
