After Effects to Premiere Dynamic Link Issue
Lauren Valko
on Jan 15, 2015 at 11:54:36 pm
I normally can figure these things out, but this time I'm stumped.
I work with the dynamic link feature a lot but I've never faced an issue like this.
The problem; I'm running into an issue where the AE file will update in premiere - i.e. if I make a change to the text it will update across platforms -- everything except for this one layer.
In the case above I'm showing you both PR and AE set at the same timestamp. It almost seems like the key frames for the circle in the background are some how not translating correctly- they're amplified and erratic. I checked and double checked my AE file. Deleting cache files doesn't seem to help and reimporting the file itself doesn't either.
The kicker is that if I check the AE source file itself in Premier alone without bringing it into the sequence it's fine. But as soon as it's in the timeline, i can't get it to display properly.
If you know problem, please help and thank you in advance!
