comp view isn't showing my content
Jerome de Win
on Jan 11, 2015 at 10:25:17 pm
When I started a new project today, my comp viewer didn't show the content I'm putting in a new composition. The comp viewer stays black, but shows the edge box of the content. So I know it's there, it's just not showing.
Here's the strange thing:
When I open older projects, comp view is showing content correctly. Adding content to it will show up too. Making a new comp is not a problem and works ok. HOWEVER... if I delete all the comps in an old project and then make a new comp, it's having the same problem as described above...
Jerome de Win
Re: comp view isn't showing my content
on Jan 12, 2015 at 3:54:51 pm
Found the problem:
fast preview was set to wireframe, causing the problem.
© 2018 All Rights Reserved
