3D text path
Erik Mickelson
3D text path
on Jan 11, 2015 at 5:04:54 pm
I feel like I have done this before.
The text layer needs to follow a spiral path "down the drain".
The path is pasted from AI as a Mask on the text layer. The text follows the path just fine to the center of the spiral using Margin Alignment keyframes. I just cannot get the type path to recede into Z-space. I have tried adding a "Position" effect and selecting Ramp Up but the text does not follow the depth correctly.
Is there a simple solution?
Erik Mickelson
Re: 3D text path
on Jan 11, 2015 at 5:14:16 pm
I should add that I can "fake it" by animating a null along the Z-axis and parenting the text layer to it. That method "works" but the path then shrinks with the null into Z-space creating an unnatural arc. The Null solution may have to work for now.
Brian Charles
Re: 3D text path
on Jan 11, 2015 at 7:39:44 pm
Would something like this work? I added scale as well as position and played with the offsets.
8396_spiral.aep.zip
Type Spiral
Erik Mickelson
Re: 3D text path
on Jan 11, 2015 at 8:02:39 pm
Very nice! I'll use this method over mine for sure.
Using the Scale with a Range Selector Offset stays truer to the path than using a null for scale(as I did). I would like to get it even closer, at about 2,10 the text veers off course a bit. I would like to keep ON the path from beginning to end. Maybe fiddling with the controls will get even closer.
I have Particular and Element 3D if anyone has a solution involving those plugs.
