Strange glitches after rendering
Bill Smith
on Jan 2, 2015 at 1:00:12 pm
Hi, I'm new to after effects. I just made my first video. I have a couple of questions. Does it usually take 1hr and 30 mins to render a 10 sec video?
My cpu fx 4170
RAM: 8GB vengance ram
I rendered my video a couple of times, when i used a third of the resolution it came out fine. Everything was in place, all the text and animation but the resolution was bad. So i rendered it in full (this took over an hour) and the text went to the left top corner twice very fast and then it came back to the middle. It did this twice.
So i rendered it in after effects as AVI then h.264 and then i put it into media encoder and rendered it and it did the same thing.
You can see what happens on that yt video.
Walter Soyka
Re: Strange glitches after rendering
on Jan 2, 2015 at 6:30:54 pm
[Bill Smith] "Does it usually take 1hr and 30 mins to render a 10 sec video?"
It can. See Improve performance [link] for things you can do to try to speed that up.
[Bill Smith] "I rendered my video a couple of times, when i used a third of the resolution it came out fine. Everything was in place, all the text and animation but the resolution was bad. So i rendered it in full (this took over an hour) and the text went to the left top corner twice very fast and then it came back to the middle. It did this twice. "
Try to clear your cache. Assuming you are using Ae CC or CC 2014, Edit > Purge > All memory & disk cache.
If you are using Ae CS6, you can purge the disk cache from Preferences > Media & Disk Cache.
Walter Soyka
Bill Smith
on Jan 3, 2015 at 6:37:58 pm
Thanks bro it worked :)
