Using Expression and Slider Effect to Animate Number Count
Lindsay Simpson
on Dec 22, 2014 at 3:14:58 pm
I am building an animated counter in After Effects CC 2014 using the expression below with a slider effect on a text layer.
Math.round(effect("Slider Control")("Slider"))
This works great! Except that it limits out at 1,000,000 and I need final count of over 9,000,000.
Does anyone know of a trick to overcome this count ceiling using this effect? Or another means to achieve the same goal?
John Cuevas
Re: Using Expression and Slider Effect to Animate Number Count
on Dec 22, 2014 at 3:24:51 pm
Instead of using a slider control, use an angle control. Type your numbers into the angle(it will convert it to degrees, on the effect, but not the number output). Angle doesn't have a limit like slider does.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Lindsay Simpson
on Dec 22, 2014 at 5:22:05 pm
Thanks for taking the time to provide feedback. I will try the angle effect, but also found that this thread helpful: https://forums.creativecow.net/thread/227/25998
