The 100: Opening Credits. How to ?
Jp Brochu
on Dec 20, 2014 at 6:00:32 pm
I would like to achieve something similar to the opening credits of « THE 100 » TV series. Not the whole thing, but simply the effect on the letters of the names.
Example here:
Does anybody have a rough idea how to achieve this?
Thank you!
Helena Masterson
Re: The 100: Opening Credits. How to ?
on Dec 21, 2014 at 6:47:34 pm
I just tried a rough test and got a similar effect by converting text to masks to animate in sections of the letters, then added the griddler effect. Knocking the rotation by +1.0º gives it the offset look and then play around with the text opacity. Only did a quick test but hope this helps!
John Cuevas
on Dec 22, 2014 at 12:49:19 pm
I was able to achieve something close to the effect using fractal noise + mosaic in a precomp to drive a displacement map effect on the text. Obviously, my attempt needs some refinement, but it might be a good starting point for you.
8322_100sampletext.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Jp Brochu
on Dec 23, 2014 at 2:51:11 pm
Thank you so much for your help! I'll have a look asap!
Richard Garabedain
on Dec 22, 2014 at 10:47:20 pm
Your best shot is a real 3d program. Even element should be able to do something similar.
