Apply Motion Tile with Warp Stabiliser
Jeffrey Carter
on Dec 18, 2014 at 7:01:02 am
I'm currently working on some footage shot with a drone. It's a little bit shaky and therefore use Warp Stabiliser to stabilize the shot, which turn out great.
Now because of the empty space on the sides of the shot I want to apply Motion Tile to fill up the gaps.
I do not want to crop or auto-scale my shot because I want to maintain the quality, so how would I achieve to apply Motion Tile to it?
The only thing that pops in to my mind is to track the shot again and somehow hook a mirrored duplicate next to it..
Is there some workaround for this?
Greetings!
JK Carter
Derek Boettcher
Re: Apply Motion Tile with Warp Stabiliser
on Dec 18, 2014 at 3:03:59 pm
The warp stabilizer effect already has "synthesize edges" option. It is under the Borders>Framing drop down. Just twirl it down and select it, then the options will un-gray in the advanced section. I would also suggest doing a detailed analysis. It takes longer but often provides a better result.
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
Derek Boettcher
on Dec 18, 2014 at 3:26:34 pm
But if you really want to use motion tile here is the workflow:
Create a comp 2x the size of your footage. Add the footage to it, and then put motion tile on the footage. Adjust your settings. Next make a comp the intended output size, and place the first comp in it as a layer. Apply the warp stabilizer effect, then choose stabilize only.
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
Jeffrey Carter
on Dec 19, 2014 at 5:12:14 am
Okay, thanks for the advice as it worked out great for me. It sounds as simple as it could be but i couldn't figure it out myself. Awesome.
The "Synthesize Edges" option indeed gives me some room to play with, although the amount of blur/feather and random vague placed pixels does not often give the best results.
Thanks for sharing!
JK Carter
