Trapcode particular (morphing one text into other)
Ambar Singh
on Dec 16, 2014 at 5:33:42 am
Thank you for your help. See this awesome clip -
watch at :20sec and :33sec (words break up into little square particles and at :33 they break apart, float and form another words).
Is it something that can be done through trapcode particular. or if not which tool can help ? would you suggest any direction ?
John Cuevas
Re: Trapcode particular (morphing one text into other)
on Dec 16, 2014 at 5:49:15 pm
Trapcode Form is probably easier for something like that, but Particular can be used.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ambar Singh
on Dec 17, 2014 at 1:28:15 am
Thank you John for your help but I don't know how to do it in particular or form, could you please suggest any tutorial or way to do it ?
Michael Szalapski
on Dec 17, 2014 at 9:38:00 pm
Follow most any "text to sand" tutorial and do it for both words. Precompose one of those and time remap it so that it's time-reversed. Then fade the two together. (That's one way.)
If you use Form to break it apart with your text in a precomp, you could simply change the precomp and then undo all your text breaking apart business. Again, there are several tutorials out there for using Form like this.
- The Great Szalam
