Model too dark after importing from Maya, solution needed!
Hugh Donnell
on Dec 13, 2014 at 2:16:44 pm
Hi, I've just imported my model from Maya into After Effects, but its too dark to see.
I used the following render passes:
specularNoShadow
Incandescense
reflection
shadowRaw
diffuseNoShadow
I've added MasterBeauty which just brightens it up and takes away any realism,
http://tinypic.com/r/fva4vt/8
but I can't seem to get the middle ground result from Maya which was a reasonably shaded model???
http://i59.tinypic.com/2zjf8kk.jpg
Walter Soyka
Re: Model too dark after importing from Maya, solution needed!
on Dec 15, 2014 at 3:54:06 pm
Are you using appropriate color space in Ae for your 3D outputs? In other words, are you rendering linear or sRGB from Maya?
Walter Soyka
Hugh Donnell
on Dec 15, 2014 at 4:36:40 pm
To be honest I'm not sure, whichever the default one is as it's the first time I'm using this. I think it's down to how I'm compiling each layer when I bring them down onto the composition in AE, it's probably just getting the right combo but I'm still clueless as what that is...
Walter Soyka
on Dec 15, 2014 at 5:15:50 pm
[Hugh Donnell] "I think it's down to how I'm compiling each layer when I bring them down onto the composition in AE, it's probably just getting the right combo but I'm still clueless as what that is..."
I'm not a Maya user, and it looks like Mental Ray shadow passes are not what I'd expect with my C4D background.
See here for more information:
http://www.pixelcg.com/blog/?p=981
Walter Soyka
JP Pelc
on Dec 15, 2014 at 9:11:52 pm
Yeah I would try changing the workspace in AE to linear and see if that helps. Otherwise change the color space in Maya and re export
Hugh Donnell
on Jan 16, 2015 at 3:52:42 pm
Hi, sorry for the late reply. How would I go about doing this? I'm still at the beginners stage so not sure, and I couldn't see anything online on how to do either of those things.
JP Pelc
on Jan 16, 2015 at 5:02:29 pm
No problem. At the bottom of the project window of AE you will see where it reads "8 bpc" or it may be 16 or 32. Click on that and a menu will pop up. Under color settings change working space from "none" to Adobe to just about anything else, although I would recommend HDTV (Rec. 709) or Adobe RGB or Apple RGB. Either way once you change that there is a box right underneath that should become enabled and it reads "Linearize Working Space." Check it and then hit ok.
I don't know how to change the color space in Maya as I have never used it, but a search for "change color space in Maya" should yield good results.
The video is a little long-winded but this page is a good way to start to understand what linear color space even means:
http://greyscalegorilla.com/blog/tutorials/what-is-linear-workflow-and-how-...
Hugh Donnell
on Jan 16, 2015 at 9:28:19 pm
Excellent, thanks for the help. I think I figured out why it was all so "Dark".
My object was being rendered, but all the light sources I had pointing at it weren't!
Now to figure that out ha :/
