what should I be searching for?
Ringo Speed
on Dec 12, 2014 at 8:53:28 am
I'm trying to learn how to do this effect, it's from Kill The Teddy Bear - the effect is a white point following each limb and a dynamic white line between them, sort of a dynamic graphic overlay.
What should I be googling?
Thanks in advance
John Cuevas
Re: what should I be searching for?
on Dec 12, 2014 at 12:36:06 pm
For the following each limb, you need to track them. AE has built in Motion Tracking, Mocha(third party software bundled with AE) does an even better job of tracking(tad more complicated to use). You can also hand track. Some people will use the beam effect to link the points.
Beam effect tutorial:https://www.youtube.com/watch?v=elHqinIm4RI
Another method is to use this name your price script called Connect Layers
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ringo Speed
on Dec 13, 2014 at 5:15:37 am
Thanks John, much appreciated.
