Problem when rotate masks
osama sayegh
on Dec 10, 2014 at 6:18:53 pm
Hello ,
I made a circle shape , i made a thin vertical mask with no problem , put keyframe , after couple frames i rotate this mask to make it horizontal line , i previewed it , the problem appeared , while the mask was rotating , the mask became smaller and shorter until the mask became in 45 degrees , after that the mask became bigger and longer until the mask became to the original size and 100% horizontal ,
i'm sorry for my bad English
if you didn't understand me , watch this video and i think you'll understand :
How to solve this problem ? i din't want this mask to become smaller , i want it still the same size
Dave LaRonde
Re: Problem when rotate masks
on Dec 10, 2014 at 6:57:13 pm
You aren't working in square pixels someplace in the project. Create a main comp in a square-pixel aspect ratio, probably 1920x1080 or 1280x720. Do your work entirely in square pixels.
When the time comes to render, you can next the comp containing all your work in a comp with the proper pixel aspect ratio.
Dave LaRonde
Promotion Producer
osama sayegh
on Dec 10, 2014 at 7:09:02 pm
Excuse me , i tried to work in 1920x1920 square comp
But the problem wasn't solved
In the attached video i work in 1920x1080
This problem happen only when i rotate masks
Dave LaRonde
on Dec 10, 2014 at 8:07:37 pm
Then check the pixel aspect ratio of your footage. It needs to be square-pixel, too. This kind of problem ONLY occurs when something isn't in square pixels.
Dave LaRonde
Promotion Producer
