AE quality issue
Brandon Adam
AE quality issue
on Dec 5, 2014 at 7:10:49 am
Hello CC,
You must get these quality post quite a-lot, and apologise in advance.
I have created some simple graphics and both video and graphics get rendered from AE into AME. However, the quality looks bad and looks almost as if I have upscaled the graphic from SD to HD (text is not as clear and and the colour looks washed out). I have some samples below of both a video captured from broadcast tv and my mocked graphic to compare. Hopefully you can see the difference. I basically hoping for a more professional look once rendered.
Video settings -
AE:
Comp: 1024X576 25fps
apple prores lt
AME:
MPEG2
720X576
Sample from broadcast tv (graphic at 8s) https://reels.creativecow.net/film/broadcast-tv-image-quality
My attempt: https://reels.creativecow.net/film/graphic-sample
AE File: 8269_sample.zip
Thank you.
John Cuevas
Re: AE quality issue
on Dec 5, 2014 at 2:04:48 pm
MPEG2 is a pretty lossy compression, that might explain some of the crunchiness. Does your Master(apple prores lt) look bad?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Christopher Gomersall
on Dec 5, 2014 at 3:56:53 pm
Are the graphics vector? Are you rasterizing them in the timeline? There are so many things that it could be. Without more info we are stabbing in the dark.
Kind regards,
Chris Gomersall
http://www.vimeo.com/channels/texasvideopro
http://www.youtube.com/upstairsmedia
Brandon Adam
on Dec 6, 2014 at 1:30:05 am
[John Cuevas] "MPEG2 is a pretty lossy compression, that might explain some of the crunchiness. Does your Master(apple prores lt) look bad?
Hi John,
Yes, apple pro res lt looks bad as well. SD graphics as always been a problem when it comes to quality output.
[Christopher Gomersall] "Are the graphics vector? Are you rasterizing them in the timeline? There are so many things that it could be. Without more info we are stabbing in the dark.
Hi Christopher,
No, my graphic are not vector (check AE file to make certain, im still new to AE). I also have not been rasterizing, do I have to pre-comp to use this function?
