How would i set up this colorful expression?
Richard Garabedain
on Dec 2, 2014 at 12:48:51 am
I put a wiggle on a layer's fill so that its color changes rapidly. Its for a particle system. The only problem is i get too many black and white frames when i want colors. IS there a better expression, or a little extra expression that will tell the color fill to stay out of the black and white areas.
Roland R. Kahlenberg
Re: How would i set up this colorful expression?
on Dec 2, 2014 at 1:49:23 am
What does your Expression look like?
Cheers
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Richard Garabedain
on Dec 2, 2014 at 4:58:24 am
its just a wiggle. I did lower the wiggle amount, that helped and will work well enough if i don't get a definite answer.
John Cuevas
on Dec 2, 2014 at 2:46:36 pm
You need to give us more information. Did you apply an effect to the layer, or is it a text layer? What is the layer's original color, how much of the color spectrum do you want to affect--1 channel, all 3 channels? And to Roland's query, exactly what expression did you apply to the fill?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Walter Soyka
on Dec 2, 2014 at 3:09:40 pm
[Richard Garabedain] "IS there a better expression, or a little extra expression that will tell the color fill to stay out of the black and white areas."
You almost get this for free by starting with the HSL (Hue/Saturation/Lightness) color model instead of RGB. You can convert between them [link] in your expression.
Vary the hue as much as you like; keep the saturation and lightness within ranges to limit blacks and whites.
Walter Soyka
JP Pelc
on Dec 2, 2014 at 7:22:28 pm
I would add a wiggle expression to the hue setting in an HSL effect, not a fill.
