MasterEffctLayer!!!
Al Arjmandi
MasterEffctLayer!!!
on Nov 30, 2014 at 12:58:25 am
Hi
I am wondering if is any way to stack up combination of some effects in a layer or adjustment layer to reuse. But I need a flexible layer like a MasterEffctLayer which can control later and Chang as you wish. Then you could stack up this layer on top of different videos and footage and if you change your mind by some of the effects you just edit the MasterEffctLayer and all footages under this MasterEffctLayer in every composition suddenly change in same fashion.
Todd Kopriva
Re: MasterEffctLayer!!!
on Nov 30, 2014 at 1:37:39 am
You could save an animation preset to reuse a bunch of effects, properties, keyframes, and expressions.
Or, if you want to keep things live, you can use the Copy With Property Links feature to link items to a master layer.
After Effects product manager and curmudgeon
After Effects team blog
Al Arjmandi
on Dec 1, 2014 at 7:30:35 am
Thanks mate,
Unfortunately, I can not afford CC at the moment still on cs5.5, any other solution for me?
Roland R. Kahlenberg
on Dec 2, 2014 at 1:00:54 am
Depending on the type of effect you want, an Adjustment Layer will do the job nicely.
HTH
- Roland
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Michael Szalapski
on Dec 2, 2014 at 5:19:46 pm
You can link effects with expressions to a master control layer in CS5.5 too; you have to do it manually though.
- The Great Szalam
