Final Animation for TV - Bitrate and audio Problem
João Queirós
on Nov 28, 2014 at 10:25:46 am
Hi all,
I´ve done an animation at 720x576. Square Pixels. Frame Rate: 25 fps. The animation have 20 seconds.
When i do the final render in after effects. I choose MPEG2. And i wanted the bitrate to have at least 16 Mbps. But it gives me only 4.20 Mbps. What can i do?
And the audio needs to come together with the video. And in this format the audio comes apart in a *.mpa extension. Help please.
The video settings for the video on the TV channel are these:
Vídeo
• Format: MPG2
• Bit rate mode: Constant
• Bit rate: 20.0 Mbps(minimum)
• Width: 720 pixels
• Height: 576 pixels
• Display aspect ratio:
Original
• Frame rate: 25 fps
• Chroma subsampling:
4:2:2
• Scan type: Interlaced
• Scan order:Top Field First
Thanks in advance.
Kindly Regards,
João Queirós
http://www.joaoqueiros.com/uk_index.php
Dave LaRonde
Re: Final Animation for TV - Bitrate and audio Problem
on Nov 28, 2014 at 3:49:42 pm
What kind of file are you required to deliver? How will it be used?
Dave LaRonde
Promotion Producer
