Removing Pink Smudge on Lens
Tim Franklin
on Nov 26, 2014 at 4:36:39 pm
Hi all,
I got a piece of B-roll footage and throughout most of the shots there is a pink smudge on the lens. Not sure how this happened but I was wondering if there is an efficient way of removing this?
-Tim
Tim Franklin
Freelance Visual Effects Artist/ Video Editor
Media Asset Manager, CBS Sports Network
http://www.TimSFranklin.com
Graham Macfarlane
Re: Removing Pink Smudge on Lens
on Nov 26, 2014 at 6:23:17 pm
If the smudge is transparent enough and fairly even (e.g non streaky), you should be able to draw a simple feathered mask around it on an adjustment layer, with the pen tool.
Then you can apply some colour correction effects to the adjustment layer to counter the smudge.
Edit: You might also want to apply a subtle sharpening effect to the adjustment layer too, if the smudge is noticeably blurring the image.
Graham Macfarlane - CGI specialist
Elyarch Ltd - London UK
3D Studio Max | Vray | Pflow | PhoenixFD | After effects | Mocha
Tero Ahlfors
on Nov 26, 2014 at 6:52:40 pm
Microfiber cloth, before shooting ;)
Tim Franklin
on Nov 27, 2014 at 2:04:47 pm
Good idea, the color correction approach should work in the scenario. As for the cloth- you would think this would be considered before shooting, right? I'm just the post guy though...
Tim
Tim Franklin
