Trapcode particular/ particles - placing behind the subject
Nikhil Dharne
on Nov 25, 2014 at 11:00:02 am
This is a beginner level question here.
i have shot a video wherein the character (subject) is radiating black mists / particles.
so i'm facing a problem of placing the particles behind the subject..
right now i'm at stage where i can only place particles in front of the subject but not behind it.
kindly help.
will be grateful.
Walter Soyka
Re: Trapcode particular/ particles - placing behind the subject
on Nov 25, 2014 at 1:39:12 pm
You need to separate the subject from the background, either by keying or by rotoscoping. Once you have separated them, you can use Particular's obscuration layer feature [link].
For keying, start here:
http://helpx.adobe.com/after-effects/using/keying.html
For rotoscoping, start here:
http://helpx.adobe.com/after-effects/using/animating-shape-paths-masks.html...
An oldie but goodie:
https://library.creativecow.net/articles/oconnell_pete/roto.php
Also consider the Rotobrush tool, which helps automate rotoscoping (but which isn't perfectly intuitive and will require you to read up a bit):
http://helpx.adobe.com/after-effects/using/roto-brush-refine-edge.html
Walter Soyka
