Rotating a gear thats abnormal. Looking for a simple technique.
Mark Pfeffer
on Nov 23, 2014 at 11:15:46 pm
I'm needing to rotate a gear with pads (not a circle). Trying to figure out the best solution of execution. Any ideas?
See image below.
Dave LaRonde
Re: Rotating a gear thats abnormal. Looking for a simple technique.
on Nov 24, 2014 at 1:40:02 am
How real does this animation have to look?
Dave LaRonde
Promotion Producer
Mark Pfeffer
Re: otating a gear thats abnormal. Looking for a simple technique.
on Nov 24, 2014 at 1:52:34 am
It just needs to rotate. Those bumps need to run along the path of the shape.
Kevin Camp
on Nov 24, 2014 at 3:05:28 am
You might see if you can manipulate the Vegas effect. It seems like it would get you close...
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Joseph W. Bourke
on Nov 24, 2014 at 3:51:06 am
Another method would be to just animate text along a path. Make your path the stroked shape of the base shape without the "gear" nubs, then choose a typeface which has a squared shaped period character, and stretch that character to the height you need. Then animate the text around the path.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Mark Pfeffer
on Nov 24, 2014 at 5:37:27 am
All great options.
Figured out another solution. Ended up just making that shape and using the dash attribute on the stroke. To animate movement, I just keyed up the offset feature within.
Back in business. Thanks for all your suggestions.
Brian Charles
on Nov 24, 2014 at 6:34:36 am
Shape layers?
oops too late...
8217_shapes.aep.zip
Conveyor Belt
