render multiple projects using aerender.exe from command line at once
Lal XaDa
on Nov 20, 2014 at 11:49:55 am
Hi All,
As the title says how i can render multiple projects using aerender.exe from command line at once.
e.g
aerender.exe -project /path/to/prject1 -comp "comp1" -output out1.mov
aerender.exe -project /path/to/prject2 -comp "comp1" -output out2.mov
it just render the first one and throws error for the second one
"rendering error while writing to file. an output module failed..........."
